Post Reply  Post Thread
Attempt at Juggernaut Rules
Author MessageAttempt at Juggernaut Rules
Pyro Stick
Greater Daemon of Hashut
Posts: 3,565 - Feb 2007
Group: Immortals
Market Rep: 14
Slaves: 936
Word of Hashut - Contributor Bronze Army Medal - 1000 PTS Image Gallery Contributor - Bronze Chaos Dwarf Radio - Contributor Veteran Medal - Silver Photobucket Migration Hellsmith - Bronze
Post: #1
Attempt at Juggernaut RulesPyro Stick 08-23-2007
Here is some rules i have so far. I have yet to do the cannons and some other little bits.
Chaos Dwarf Juggernaut
Cost: 220 Points per Juggernaut
Crew: 2 crew on the bottom and 1 for every level of the tower after that and 1 Boar Centaur to push it.
Profile
M WS BS S T    W   I  A Ld
*   0   -  -  7 5(+1) - 1* -
*Movement is the same as the Boar Centaur pushing it
* 1 Attack for every crew member in the Juggernaut, +1 for every crew member in every additional tower.
Wounds- 5 wounds +1 for every tower added up to a max of two extra towers after the first original one.
The Juggernaut provides the crew with a 4+ save before the crew takes their Armour Save. The crew all have Heavy Armour. The Crossbowmen have a crossbow and a Hand Weapon
The Boar Centaur pushing the Juggernaut has the same profile as the ones pushing the Whirlwind and Tenderiser.
Chaos Dwarf Crossbowmen Profile
4 4 3 4 4 1 2 1 9
Champion-4 5 4 5 4 2 3 2 9
1 Champion per Juggernaut
Boar Centaurs do not have Champion
Juggernaut Options
*May be upgraded with Skins of the Foes for 20 points
Skins of the Foe
The Juggernaut walls are adorned with the skins of the enemy. This gory sight causes the Juggernaut to cause Terror when it charges and Fear when it is charged.
*May add an extra tower to the Juggernaut for an extra 30 points for every tower up to an extra two after the first original one.
*For every tower the crewman is a Chaos Dwarf Crossbowman. This may be changed to more than 1 Chaos Dwarf Crossbowman for 8 points for every additional Crossbowman up to an extra 3 for every tower platform consisting solely of Chaos Dwarf Crossbowman. The Chaos Dwarf Crossbowman may be changed to a Boar Centaur Crossbowman for 50 points. Boar Centaur break normal Crossbows by accident when they try to use them so a more robust Crossbow was designed for them. Boar Centaur Crossbows follow the rules for Bolt Throwers when attacking with the following exceptions- It has a range of 25 inches and the strength is 5-1 per rank. Boar Centaur Crossbowmen have a BS of 4. The Boar Centaur Crossbow doesn�t count as a War Machine.
The Chaos Dwarf Crossbowman may also be changed, on the top platform only, to a Chaos Dwarf Mortar for 60 points. ( profile for the mortar will be added later)
Special Rules
The Juggernaut counts as a Large Target and provides Hard Cover for the Crew.
When the Juggernaut charges it causes 1D6+1D3 strength 5 hits
Attacking the Juggernaut
Close Combat Attacks hit automatically.
Shooting attacks roll a D6
D6 Result
1-3 Crew
4-6 Juggernaut
When the Juggernaut is destroyed all models on board must pass a Toughness test or suffer 1 S5 hit. Survivors are placed where the juggernaut was destroyed
EDIT: Newest Version of these rules can be found here: http://www.chaos-dwarfs.com/wiki/index.p...naut_Rules
My Chaos Dwarf Collection: GHXXVI
This post was last modified: 06-02-2009 05:41 AM by Pyro Stick.
08-23-2007 02:37 PM
Willmark
Dark Lord of Hashut
Posts: 7,873 - Aug 2007
Group: Hashut's Admin
Market Rep: 25
Slaves: 1219
Artisan's Contest - Gold Image Gallery Contributor - Gold Best Overall Member - 2007 Word of Hashut - Contributor Chaos Dwarf Radio - Contributor Best Contributor - 2008 Best Overall Member - 2008 Best Overall Member - 2012 Veteran Medal - Bronze Diamond Army Medal - 8000 PTS
Post: #2
RE: Attempt at Juggernaut RulesWillmark 01-05-2009
Now that the Second and Third issues of the Word of Hashut are out why don't people give these rules a try and reply back here with feedback. I'd be interested to hear how they play out in 7th edition.
My Want List / My Trade List
This post was last modified: 01-05-2009 11:18 PM by Willmark.
01-05-2009 11:15 PM
Pyro Stick
Group: Immortals
Market Rep: 14
Slaves: 936
Post: #3
RE: Attempt at Juggernaut RulesPyro Stick 06-02-2009
Ive added the revised rules that i entered into the AC, along with the fluff, to the cdo wiki Fan Rules page of mine:
This post was last modified: 06-02-2009 05:43 AM by Pyro Stick.
06-02-2009 05:43 AM
jolpis
Chaos Dwarf Sorcerer
Posts: 339 - Jun 2008
Group: Dawi Zharr
Market Rep: 0
Slaves: 0
Post: #4
RE: Attempt at Juggernaut Rulesjolpis 06-02-2009
love the idea of adding towers Good work! surviving crew the fear causing is a bit underpriced but its a good idea with the customizing and all
-The ships hung in the sky in much the same way that bricks don't.
-the hitchikers guide to the galaxy... pure genious!
06-02-2009 12:44 PM
AtomTaylor
Chaos Dwarf Daemonsmith
Posts: 188 - Sep 2015
Group: Dawi Zharr
Market Rep: 3
Slaves: 189
Hellsmith - Silver
Post: #5
RE: Attempt at Juggernaut RulesAtomTaylor 05-17-2018
Great work Pyro, I'd reduce the movement speed a bit as its being lugged along by one creature. I would also give options for an extra Boar Centaur pusher.
Also It should not be able to be normally pushed up hills or over broken ground. All in all very concise, much appreciated.
https://www.facebook.com/OldschoolMinis
05-17-2018 08:26 AM
Abecedar
Curmudgeon of Hashut
Posts: 4,390 - May 2010
Group: Immortals
Market Rep: 14
Slaves: 1562
Best Attitude - 2016 Word of Hashut - Contributor Veteran Medal - Silver Artisan's Contest - Silver Diplomat Medal - Bronze Diamond Army Medal - 8000 PTS Scribe's Contest Veteran Artisan's Contest - Gold Scribe's Contest Bronze Scribe's Contest - Gold x2 Scribe's Contest - Silver x2 Golden Hat - Bronze x2 Artisan's Contest - Bronze x2 Golden Hat - Gold
Post: #6
RE: Attempt at Juggernaut RulesAbecedar 05-18-2018
Pyros rules were what drew me into firstly the Hand of Hashut forum and then here.
I had collected models and wanted rules to play them and his is what I found
Army Blog
Short Stories
Legend of Lord Kvackd'up
Zhek'dars tales  =  tbf.
05-18-2018 12:38 AM
Admiral
Auxilliary Moderator
Posts: 6,564 - May 2011
Market Rep: 8
Slaves: 714
Scribe's Contest - Bronze x3 Best Attitude - 2014 Best Contributor - 2014 Major Prize Sponsor Golden Hat - Bronze x2 Scribe's Contest Veteran Scribe's Contest Silver Hellsmith - Gold Dark Apostle - Silver Best Attitude - 2015 Best Overall Member - 2015 Best Contributor - 2015 Artisan's Contest - Silver Best Overall Member - 2016 Best Contributor - 2016 Artisan's Contest - Gold
Post: #7
RE: Attempt at Juggernaut RulesAdmiral 05-30-2018
A living resource still relevant to the rather popular 3rd edition, and a resource which ensnared Abecedar. Well worth refreshing. Takes Hat off
News on CDO: Artisan's Contest XXVI - Voting Deadline 27th of January ...  Etsy shop
Chaos Dwarf Writings: Fables. Songs. Sayings. Quotes. Monumental Inscriptions. Religious Texts.
There's fourteen ways to skin a dwarf. Path to Glory: Chaos Dwarf Warband Rules.
05-30-2018 05:57 PM
Possibly Related Threads...
Exclamation My Juggernaut rules Joshmohr 11 3,420 02-19-2009 07:30 PM
Last Post: wallacer
View a Printable Version
Send this Thread to a Friend
Forum Jump:
